Create an MSDP peer
Perform the following procedure to establish a peer relationship between the local MSDP enabled
router and a peer in another domain.
Important
Do not enable more than 20 active peers.
Switch:1>enable Switch:1#configure terminal Switch:1(config)#ip msdp peer 21.0.0.2 Switch:1(config)#ip msdp peer 21.0.0.2 enable Switch:1(config)#ip msdp peer remote-as 1
Variable definitions
The following table defines parameters for the ip msdp peer command.
Variable |
Value |
{A.B.C.D} |
Specifies the MSDP peer IP address. |
WORD<0-11> |
Specifies the AS number of the MSDP peer, 0-65535 (2-Byte AS) 0-4294967295 (4-Byte AS). |
